73 horn relay - NCRS Discussion Boards
73 horn relay
  • Lynn S.
    • November 1, 2004
    • 99
    73 horn relay
    Can someone tell me the correct way to check my 76 horn relay. When power is applied to the relay I hear the "click" but how do I check continuity of the relay? Thanks, Lynn Schwebach
  • Rich C.
    • January 1, 1994
    • 383
    Re: 73 horn relay
    Lynn,
    Can I assume your horn isn't working? I would unplug the horn and check for voltage when you hit the horn button. If you hear the relay click, I would assume the continuity of the relay coil is good.
    1973 LS-4 454 coupe, owned 24 years
    1996 LT-4 CE coupe, owned 1 year
    Smu ttynose 'Finestkind' IPA- currently on tap!
