Converting Tri-Power center carb for manifold vacuum advance - NCRS Discussion Boards
    • 15669
    Re: Converting Tri-Power center carb for manifold vacuum advance
    Originally posted by Robert Moon (20478)
    Tim, Thanks for the response because I have the pollution control on my car will converting to full time vacuum have adverse effects?
    Bob
    No, as long as you install a B26 VAC (the OE L71 201 15 will not meet the Two-Inch Rule) in conjunction with converting to full time vacuum advance and go through the idle speed/mixture adjustment procedure when the conversion is done and the B26 is installed.
    I recommend a target idle speed of 900.
    • Robert M.
      • January 1, 1992
      • 78
      Thanks for the responses, I will put on the b-26 can and do the conversion
      Bob
      • R N.
        • May 31, 2002
        • 640
        #18
        When I did my '66 L-72 about 12-years again, Duke helped me much and Clem talked me through modifying my carb base. I'm posting a picture of the modified base as it should help others with a single 4-barrel carb.
        The area circled in RED is the small hole I plugged with epoxy and the GREEN circle is the newly opened up tunnel to have full-time vacuum and the BLUE arrow shows the original vacuum routing.
        In addition to the carb-base modification, I changed the VAC and re-did the timing.
