C2 Rear Suspension Ride Quality - NCRS Discussion Boards
  • John L.
    • 100
    Is rear suspension ride quality (smooth, no excessive bounce) largely a function of two things, quality/condition of the shocks and leaf spring? thanks
    • 15667
    Re: C2 Rear Suspension Ride Quality
    Hardened and compressed spring link cushions dramatically increase rear ride harshness in addition to loosing rear ride height.
    IMO they should be replaced about every 5-7 years, even if the car has little mileage accumulation.
    • Leif A.
      • August 31, 1997
      • 3627
      Typically, your shock absorbers should control excessive bounce. Go to each rear corner of the car and push up and down on the bumper. The car should stop bouncing almost immediately after you stop pushing on the bumper. If the car continues to bounce after you have stopped you have bad shocks. Also, consider out of round or damaged tires (slipped belt, knot in sidewall, etc)...that would cause excessive bounce, as well. Springs control ride height and absorb some shock but I don't think that is what's causing your problem.
      Leif
      • Michael W.
        • April 1, 1997
        • 4290
        Type of rear spring is a big contributor too. The composite/fibreglass units are more compliant than traditional steel multi-leaf type.
          • 15667
          Actually, most aftermarket composite replacement rear springs for vintage Corvettes have much higher rates than the base suspension OE spring. Also, composite springs have much less inherent damping than the the OE spring, and most replacment shocks are designed for the latter.
          As a result, you often end up with a way oversprung and way underdamped rear suspension with resulting severe degradation of ride and handling quality.
          Springs and shocks have to be engineered as a system, but this is rarely the case with aftermarket parts. The best approach is to keep the OE spring. If you get stuck with an aftermarket composite spring and typical replacement shocks, a set of adjustable shocks like Spax or QA-1 can probably be adjusted to provide sufficient damping.
