BB Harmonic Balancer - NCRS Discussion Boards
  • Ted S.
    • January 1, 1998
    • 747
    What was harmonic balancer 3870325 used for?
    Ted
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: BB Harmonic Balancer
    my book says 1969 L-72 chevelle
    • Ted S.
      • January 1, 1998
      • 747
      The 3870325 is cast into the center hub. Is that also the GM part number (vs a casting number that they used to make various balancers out of)? It is an 8" big block balancer, so I thought it was for hipo applications. Were 8" big block balancers used for non hipo applications?
      TIA
      Ted
      NCRS #30057
      • Craig S.
        • June 30, 1997
        • 2471
        I am not sure in the older cars, but, my 81 454 pickup has an 8" balancer....Craig
          • 43259
          Ted----
          The number that you are referring to is a casting number for the balancer hub section; it is not a part number for a complete balancer assembly. That hub may or may not have been used for several balancers.
          The 3870325 hub was a non-counterweighted balancer hub. So, the balancer that you have is very likely one of the 66-70 balancers used for SHP 396, 402, and 427 engine applications.
