66 Steel Wheel ID location - NCRS Discussion Boards
  • Peter M.
    • February 1, 1984
    • 361
    I provided a previous response to a member question about 66 steel wheel ID as follows: "1966 base wheel was the same as 1965 and was a regular production (short spoke spyder) size 15X 5.5 steel wheel. It was stamped 15X5 1/2, 65, JK on the inside and the name Kelsey Hayes was stamped inside a circle. You can see this infor in Noland Adams Vol 2 Page 265"
    New Question - was 65-66 steel wheel ID only on the inside and not seen when a tire is mounted? Any ID features on the front or rear side of the 65-66 steel wheels that would ID a correct 65-66 Corvette Steel Wheel when a tire is mounted?
