When I pull the light switch on, the headlights come on properly, but the tail lights are very dim, just barely visible. If the headlights are unplugged, the tail lights are still at the same dim level. However, when the turn signal switch is turned on, the tail lights blink at a normal (acceptable) brightness. Someone suggested that there might be a ground problem. Does that sound likely ? I've seen in the manuals that there are several ground straps, but I have not chased them all down to see if they are in place. What functions are they critical for?
Steve
Steve
