New Use of E-bay - Involves High Horse 427s C2 C3 - NCRS Discussion Boards
  • Tom D.
    • September 30, 1981
    • 2134
    I copied this directly from an e-bay listing. The current bidder, yes there is one, is at $ 0.01 (cents). There is also a posted follow up question from someone who did not understand the following!
    Entered here by member number 4889 (Tom Dingman), just in case you know of these serial nums.
    THE OWNER OF THIS BLOCK WILL ACCEPT A REASONABLE OFFER. PLEASE EMAIL ME FOR DETAILS.
    PLEASE READ CAREFULLY!!! YOU ARE NOT BUYING AN ENGINE BLOCK, ONLY MY HELP IN OBTAINING IT.
    I HAVE LOCATED A 1968 CORVETTE 427/435 HP ENGINE BLOCK SERIAL # 18S417807 CASTING # 3935439 AND I AM TRYING TO REUNITE IT WITH THE CURRENT OWNER OF THAT CAR. THE ENGINE PAD IS FACTORY STAMPED TO424IR 18S417807
    I BELIEVE THAT THIS DECODES AS THE CAR WAS BUILT APRIL 24 OF 1968 AND WAS EQUIPPED WITH A 435 HORSEPOWER 4 BOLT MAIN ENGINE.
    I WILL TRADE THIS BLOCK FOR A CORRECT 1966 425 HORSEPOWER BLOCK WITH FEBRUARY OR EARLY MARCH DATES
    I AM SEARCHING FOR MY ORIGINAL BLOCK WHICH WAS 6S117435 CAN YOU HELP?
    PLEASE NOTE: I AM WILLING TO BUY MY BLOCK OUTRIGHT IF YOU DO NOT WISH TO TRADE.
    EMAIL YOUR RESPONSE THROUGH EBAY. THANK YOU!
    ***TO THOSE OF YOU THAT DID NOT READ THE FIRST SENTENCE----- YOU ARE NOT BUYING A BLOCK-----ONLY HELP TO REUNITE YOU WITH YOUR ORIGINAL BLOCK
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
