Original Z06 Heavy Duty Brakes - NCRS Discussion Boards
  • Michael B.
    • November 1, 1984
    • 57
    Re: J65 pucks (comparison) Phil C & Joe#930
    Here are some pics that I picked-up somewhere of the ZO6 convertible that I believe was for sale awile back.
    Mike
    • Alan Drake
      Re: Heavy Duty Brakes Stopping
      When cold the first stop is not there at all. You only do that once, then you put brakes on when driving away, just a short distance. After that you stop better then the others.
      • Joseph T.
        • April 30, 1976
        • 2074
        #18
        Thick pads
        Michael..interesting..they have the same thick pads...and manufacturing marks.
        • Joseph T.
          • April 30, 1976
          • 2074
          #19
          Alan..not to be funny..but if that is the case..then unloading from a trailer could be interesting.
          Joe
            • 15706
            #20
            The lining segment dimension data for J-65 and HD brakes is listed in the AMA specs.
            • Verne Frantz
              #21
              Try parking a stick shift car on a hill using the emergency brake. Leave the car in gear while parked so it doesn't move, but then, when it's time to go, press the clutch in to start the engine before it rolls into whatever is closest to you. Or you could try to heel-toe it until it starts. It's like having no brakes. Down-rite dangerous under certain circumstances.
              But I wouldn't give them up for anything..... One just has to understand where the safe limits are.
              Verne
              • Rick A.
                • July 31, 2002
                • 2147
                #22
                Re: Original Z06 Heavy Duty Brakes
                if you want - I can get the numbers off my drums and shoes for my 1963 Z06 - they are packed away in boxes
                Rick Aleshire
                2016 Ebony C7R Z06 "ROSA"
                • Joseph T.
                  • April 30, 1976
                  • 2074
                  #23
                  Rick..when you get a chance..I would be interested in the casting numbers on the rim face of the drums and also the stamped or inked #'s on the shoes.
                  On the 63 Z06 drum below..the # appears to be 3841832
                  Joe
                  • Philip C.
                    • December 1, 1984
                    • 1117
                    #24
                    Re: J65 pucks (comparison) Wayne
                    Hi Wayne on your Front J65 shoes in the photo 5461962 should be stamped in. PS Thanks for the survey. Phil 8063
