water pump 71 - NCRS Discussion Boards
water pump 71
  • lyndon sharpton
    water pump 71
    on my LS-5 pump I could not find a long casting # just the GM 8T an a date code on the other side.
  • Warren F.
    • December 1, 1987
    • 1516
    Re: water pump 71
    The seven digit raised casting number is BARELY VISIBLE, as it is ALMOST completely hidden by the pulley that is mounted to the waterpump, it is located on the same side as your GM 8T, just inboard of the outside edge of the waterpump pulley.
    • lyndon sharpton
      Re: water pump 71
      on mine the pulley covers all of that # it is so close I dont know how you would see it with out taking the pulley off
        • 43219
        Re: water pump 71
        lyndon-----
        You can't see it without taking the pulley off.
          Add on...
          Joe's dead nuts on! That's why the policy on early Shark cars is to PROHIBIT judges from attempting verify water pump casting number/casting date.
          I suppose it might be possible to get behind the pulley with a flexible illuminated viewing tool (borescope, labroscope), but where does the foolishness end! My hat's off to early Shark National Team Leaders who wrote the policy of preventing such foolish attempts in judging heroism...
