67 L89 Radiator - NCRS Discussion Boards
67 L89 Radiator
  • Rob Harper
    67 L89 Radiator
    Quick question, what radiator was installed in the 67 L89's? Which GM part number?
    Rob
    • 43219
    Re: 67 L89 Radiator
    Rob------
    The original PRODUCTION radiator was GM #3008567. This is a copper brass radiator with no oil cooler provisions and with integral filler neck. It's the same unit as used for all 1966-68 Corvette applications with 427 cid engines and manual transmissions EXCEPT 67-68 L-88.
    The GM #3008567 was discontinued many years ago and replaced, for SERVICE, by the GM #3008566. The latter is an identical radiator except that it has an integral oil cooler and fittings. It's also discontinued now.
      • 43219
      Re: 67 L89 Radiator
      Rob------
