P235-75-15 - NCRS Discussion Boards
P235-75-15
  • Chuck R.
    • April 30, 1999
    • 1434
    P235-75-15
    Will P/235/75/15 tires adequately fit into the wheel wells of my 68 without rubbing?
    Chuck 32205
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: P235-75-15
    Probably yes, but why not use something a little closer to original?
      • 15667
      Re: P235-75-15
      Go with one of the three V-rated P225/70R-15 police pursuit tires.
      • Chuck R.
        • April 30, 1999
        • 1434
        Re: Thanks Duke & Wayne
        As always I appreciate your responses.
        Chuck 32205
        • Chuck S.
          • April 1, 1992
          • 4668
          Yeah, Chuckster...
          Git yerself uh John Deere iffn' ya lak reely beeg tahrs!
          • Mark #28455
            Re: P235-75-15
            I've used 235-60-15's on the stock 8" rims for my 69 and 70's with the F41 suspension and they don't rub.
              Re: P235-75-15
              75-section tires are kinda skinny compared to the aspect ratio of the originals...
              • Chas Kingston
                • Mark #28455
                  F70-15 was original *NM*
                  • Chuck R.
                    • April 30, 1999
                    • 1434
                    Re: I cud harrow da gurden et da sam time
                    I culd git sum of dem biiiiig ole double ought ones
                    Chuckster 32205
                    • Sal C.
                      • December 1, 1984
                      • 430
                      Re: P235-75-15
                      I tried to put a set of Goodyear Eagle RS-A P235/75R15s on a 1970 with F41 without success. They would probably fit with the standard suspension. I'll give any member a great deal on them. E-mail me if you are interested.
                      • Richard D.
                        • December 1, 2002
                        • 328
                        Re: P235-75-15
                        Sal:
                        I put on a set of Firestone Firehawk 235/60 15's on my 68, and they do rub just a little at full wheel lock.
                        I now wish I had gone with the Police tires that Duke and others are recommending.
                        I got a price on the police tires at around (Firestones they were) 120 each.
                        The Firehawks were 65 each.
                        Since I don't drive my car that hard, I figured they would be OK, given the cost savings, and the other stuff I needed at the time!
                        Rich
                        • Mark #28455
                          Re: P235-75-15
                          If the section width is the same (235) then the 75 profile is larger diameter than the 60 series, so wouldn't the 235-75-15 rub worse than the 235-60-15?
                          Mark
