1967 AM/FM radio - NCRS Discussion Boards
1967 AM/FM radio
  • Chuck M.
    • February 1, 2002
    • 335
    1967 AM/FM radio
    When tuning the antenna and my hand is on the antenna the AM band tunes perfect. When I remove my hand from the antenna the AM band is VERY weak, is this a grounding issue? Thanks for the help.
    Chuck
  • Mike M.
    • May 31, 1974
    • 8382
    Re: 1967 AM/FM radio
    i suspect it is a ground failure- suggest putting external tooth lock washers on both ends of the copper ground strap . also make certain the ground plane plate isn't oxidized where it and the antenna main body make contact. good luck, mike
