63 Door Hinge Bolts - NCRS Discussion Boards
63 Door Hinge Bolts
  • Stephen G.
    • January 1, 2002
    • 304
    63 Door Hinge Bolts
    I'm trying to identify the correct bolts that are used to hold the door hinge into the door jam. These would be the 2 bolts you can see on each hinge in the jam when the door is open (not the 2 inside the bird cage that you cannot see).
    They are 5/16-18 x either 7/8" or 1". They are plated black phosphate. My hinges are marked with serrations indicating that the bolts had a captured lock washer. I have found 3 of these in my pile. They have a head mark with a "C" dissected by small lines at Noon, 6 and 9 o'clock.
    Paragon calls out for the same bolt but it has a captured FLAT washer. Also they show a head mark a small "E" in the center and small lines at 9, Noon, and 3 o'clock.
    LIC does not detail the bolt.
    Thanks for any input.
    Steve Gansky
    Newtown, (Bucks County) PA
  • Kenneth S.
    • July 31, 1981
    • 302
