Re: C2 Head Lights - NCRS Discussion Boards
Re: C2 Head Lights
  • John Lokay
    Re: C2 Head Lights
    Kent, where is the ground wire located? Is there a ground wire for each head light bucket?
  • Carl R.
    • March 1, 1998
    • 166
    Re: C2 Head Lights
    Hi Mr. Lokay,
    Each headlight motor has a black ground wire that attaches to the front header panel support with small sheet-metal screw (if I remember correctly). Easiest way to find is to put fluorecent droplight in front of radiator support and use an inspection mirror (or old vanity mirror, if you can surrepititiously borrow...)
    Carl
    • Wayne W.
      • April 30, 1982
      • 3605
      Re: C2 Head Lights
      The ground wire screws into the motor case. Under the same screw that retains the brace that goes to the header bar.
      • Carl R.
        • March 1, 1998
        • 166
        Re: C2 Head Lights - Apologies!
        Haven't done this job in a while!
        Carl
