crossmember repair - NCRS Discussion Boards
crossmember repair
  • Calvin C.
    • May 31, 2002
    • 240
    crossmember repair
    i have a 73 convertible. the front cross member is cracked. i have been told a good welder can repair it by welding reinforcement plates over the damaged area. is this an ok to reoair it.
    cal
  • Craig S.
    • June 30, 1997
    • 2471
    Re: crossmember repair
    If you are speaking of the steel "skin" underneath the crossmember, that is not a structural item, and can be obtained from suppliers and welded back in. Even if you are speaking of the areas where the crossmember joins the siderails, this can be effectively repaired and welded...Craig
