Computer Question for this site. - NCRS Discussion Boards
  • Larry E.
    • 1674
    I have an older Compaq Laptop with Windows 98 SE. It has Explorer #6 for the browser. I use this
    computer for a "backup" and use it once in a while. It will bring up (slow) all my favorite sites except
    this site for some reason. Window comes up and says it can not bring up this site. I'm sure it has some-
    thing to do with the "cookies" or perhaps security settings. Any ideas?? Need help on how to reset
    the "settings" so I can bring it up. Thanks in advance. Larry
    Larry
    LT1 in a 1LE -- One of 134
  • Don H.
    Moderator
    • June 16, 2009
    • 2254
    Re: Computer Question for this site.
    Hi Larry
    Your question is best moved to the Discussion Help Board, and either John W or Gary C or Rob M will give you the best answer.
    I know that the NCRS website functions best on browsers such as Chrome and Mozilla Firefox.
    Those may not even be supported in your old 98SE operating system.
    I will drop a note to the fellows above to get you the definitive answer to your question.
    Thanks for using the Technical Discussion Board!
    ps Larry, I just looked up Explorer 6 to learn about it and I see that it is a 10 year old system and
    only 6% of the world still uses it, over half that number in China. Only 1.1% of all USA and Canada internet usage involves IE6.
    This tells me that the browser is utterly obsolete, and incompatible with the NCRS website and your settings and cookies will not fix it.
    I don't think your old Compaq will be any use to you for this site.
    • John W.
      Administrator
      • November 1, 1974
      • 5087
      Larry,
      There are several issues with I.E. 6 that would prevent the TDB from displaying. The Technical Discussion Board is not a Static Site. It is built as you access it depending on information passed back and forth between your computer and our server. Are you logged in? You get one view if you aren't and another if you are. What are the new posts since you last visited? We ask your computer for the last time you were here and build that information custom for your view. This is all done with a combination of cookies which I.E 6 does support and Java which I.E. 6 barely supports. There are a lot more versions of Java than there are of I.E. and older versions don't support all of the functions.
      Bottom line is Win 98 SE is just too old to support. We add features to accommodate newer technology and at some point the old stuff just won't keep up.
      Administrator
      www.ncrs.org
      • Larry E.
        • 1674
        Originally posted by John Waggoner (107)
        Larry,
        John: Yes I'm logged in with my other computer. Ok will not be able to use that computer on this site. Again it works on eveybody else's site except NCRS
        which is strange to me. Thanks; Larry
        Larry
        • Gary C.
          Administrator
          • October 1, 1982
          • 17648
          Larry,
          All the other sites may not have the security enhancements that the NCRS site does which are not supported by IE6
          Gary
          NCRS Texas Chapter
          https://www.ncrstexas.org/
          • Dick W.
            • 10483
            I just checked the web sites that I have. One site had 2% using IE 6, none of the rest had not had a hit with that browser in the last 30 days. I believe most have ''stuck a fork in it'' and declared it done.
            Dick Whittington
            • Dick W.
              • 10483
              While we are on browsers an OS's, the TDB is a little flakey using Jelly Bean. Have trouble getting back to home and another little quirk or two.
              Dick Whittington
              • Michael W.
                • April 1, 1997
                • 4290
                I'm amazed to learn of a computer that still runs OK with Win 98.
                • Rob M.
                  NCRS IT Developer
                  • January 1, 2004
                  • 12729
                  I still have our ZX80 of 1978 with Z80 CPU running on only 1K of RAM which we extended later to 2k RAM,
                  my Z81 (1979) with 16k RAM,
                  ZX Spectrum (2x) (see also http://www.youtube.com/watch?v=mh0g73JvFbo),
                  a TRS80 model 1 and the good old Commodore 64...
                  Rob.
                  NCRS Software Developer
                  • Dale M.
                    • December 27, 2007
                    • 386
                    Rob, that whoke up some brain cell from the past. I started my computer career in 1969 where we just got a new IBM 360 with 16K of memory where we ran an entire railroad. We did not know how we could every use that much memory, but then COBOL cam along and showed us. We set up an online system on that machine with teletypes in our remote offices. The Engineer ran a card deck through the machine for us to track our railraad cars across our tracks. Thanks for the pictures.
                    • Larry E.
                      • 1674
                      Michael: I still have a Radio Shack "Color Computer" that works fine. Just because things get old don't mean they don't work.
                      BTW: I have two "old" Corvettes that work fine also; maybe that 2% figure may apply here also. Larry
                      Larry
                      • Michael W.
                        • April 1, 1997
                        • 4290
                        [ATTACH=CONFIG]43091[/ATTACH]
                        [ATTACH=CONFIG]43092[/ATTACH]
                        [ATTACH=CONFIG]43093[/ATTACH] [ATTACH=CONFIG]43094[/ATTACH]
                        Thanks for the blasts from the past guys. My dig was with respect to the specific product (Win 98) which didn't need the passing of a few years to become old and outdated- it was awful right out of the box and just got worse.
                        • Dick W.
                          • 10483
                          I just picked up an old Dell that was being use for point of sale QuickBooks software. I am amazed also. You can buy it on my upcoming auction.
                          Dick Whittington
                          • Rob M.
                            NCRS IT Developer
                            • January 1, 2004
                            • 12729
                            for the yougsters amongst ourselfs:
                            RadioShack Tandy TRS80 model I:
                            Commodore 64:
                            Rob.
